Heads, intakes, cams
Since you have a mag motor, you should already have the rectangle port heads, although mine are setup with the isky springs to match the roller cam. The cam was spec'd to match the heads and was a roller upgrade to a merc 420. With a roller cam, they were similar to the hp450.
