Marine kinetics custom cam 10hrs of use
Gen 6 hyd roller cam specs by marine kinetics 233int 237ext duration .646 .638 lift on 114lsa ran it for about 10hrs was 595.00 new i will let it go for 350.00
Good luck with sale
Was in a HP500. He is building a 540. See here: http://www.offshoreonly.com/forums/g...ml#post4553362
595 for a cam? Thats a good deal.
Crane gets 418.00 , comp 410, jones cams around 400, for billet custom ground hyd roller cams with iron gear.
Not bad though, im sure his leadtime is much faster than 4 days to get it. Sometimes its worth paying more when you need it faster.
It lasted 10 hrs? I think I have one from him that lasted about 20 hrs. He sells these cams as the latest custom grinds while criticizing all other cam companies as old technology. It is not unusual to find the specs of one of custom grinds in the shelf cam catalogs from Crane and Comp Cams. A real con artist who tries to dazzle you with technical terms he has only surface level knowledge about.
Yes i am rebuilding my hp500 into a 540 the motor was fine i just wanted more hp, and i know this doesnt help me selling it but oh well i definitely was not pleased with mk this cam was supposed to make more power i lost 1 to 2 mph with it and then he blamed everything else on why it didnt but i figured if anyone can use the specs it has for there combo then great and yes it was 595 i should have called comp or crane , isky sorry about the bashing its just my opinion thanks
