BAM Transmissions
BAM Transmissions
Looking for bam dry sump 1500 trannies. One driveline and one plug in. I have 2 1500 bams and 2 velvet drives. 2 plug in 2 drives and 2 are rebuilt. Maybe work out a trade.
Let me know what you have. Will buy trannies in need of rebuilds as well. Repowering my boat and what the dry sumps
Jay have you had a dry sump apart? There's really not much to taking a regular Borg trans and doing it. My buddy can mill the bottom off the case and make the pan if you wanted. Bam uses copper tubing from the pump pickup back to the sump of the pan. It's really a wet sump but the fluid is kept away from the rotating assembly
Yea I know there isn't much difference but having the kevlar clutches and sump they are rate for little more. The non dry sump is rate at 1100ftlbs of torque at 5k the dry sump brings it to 1250ftlbs at 5k. If i can find them soon I'll do it if not the old ones will go in.
