Best Chip/Upgrades for Duramax
Go to www.ATSDIESEL.com They have everything you could ever want. The Xcelerater gives you 204rwhp and 350+rwft/lbs just with a chip. It is sick stuff. Talk to Mike and tell him Hunter Sent you. He will hook u up.
Hunter
Hunter
Originally Posted by jordy
Edge, hands down. I've run one on my truck for 30K miles and not had any problems, that includes trips down the drag strip. I'm running on 285's to boot. Personally, I think it's the best performance hop up on the market. I'm also running Gibson exhaust and a K&N FIPK kit, which they just came out with for the LLY recently. ![Cool](/forums/images/smilies/cool.gif)
I made it easy and went with Hypertech. It has three different power levels and the top one will smoke the tires, so I went to the lowest and it still rocks. No other mods needed, just plug it in follow the prompts and then go. $375
for the guys running the programmers I would highly recommend a boost and pyrometer gauge installed, You would be amazed at what the temps climb like when towing and a turbo bark is very nasty!
Cobra, the lly is the newest version of the duramax, believe it changed in 2004.5 the old ones are the lb7 check out www.dieselplace.com has its own section on them type of rigs.
Thanks for all the information. After looking at all the websites and doing a bit more research, I ordered everything through PMT in Florida. They were extremely knowledgeable about what works and what doesn't. I decided on the Banks 6-Gun with Speed loader since it seems from everyone I talked to that the Edge still has a few problems for the LLY engine (Hands down it is the favorite for the LB7). I also ordered an air box, guages, and dual exhaust. I was planning on doing the full exhaust and removing the cat, but both Connecticut and New York are becoming even stricter on emmissions, so I figured I better leave it alone.
Edge with Attitude is what seems the fashion here;
http://dieselplace.com/forum/forumdisplay.php?f=3
thunderdan
20
04-08-2010 10:04 AM
Harper220
17
12-11-2005 07:33 AM
BAD HTM SR 24
12-27-2002 05:34 PM
