| OSO Sponsor |
| OSO Sponsor |
02-19-2006, 01:27 PM
1998 Cigarette Top Gun
Does this look normal?
02-19-2006, 01:34 PM
Re: Does this look normal?
My power steering pump blew (I'm pretty sure since it leaked fluid EVERYWHERE) and it somehow blew this pulley out which stopped my alternator from charging and stopped the radiator fan from moving. So I drove home from work the other night with no power steering, my batter gauge showing no amps, and my temperature gauge spiked to 260. I turned the heat on, nothing but cold air came out and didn't help the engine temp any. Can't wait to see how much this will set me back.
02-19-2006, 07:44 PM
velocity
is that a jeep i have seen it before also you need to clean that battery
02-19-2006, 08:37 PM
Yeah it's a Jeep Grand Cherokee with a 4.0L I-6. You've seen that type of thing happen before? Do you know what caused it or how much it cost to fix?
Yeah that battery could use some help...it's done a good job though, it even helped jump the TG once. I'll get a new one eventually...but I'm looking at some other expenses right now
Pretty shotty wiring work too...I've been meaning to clean that up a bit.
02-19-2006, 11:20 PM
velocity
check the belt tensioner make sure it is working right and not holding the belt to tight if it is good could have been a bad pump or you may have a leak in a highpressor line causing a low power steering fluid level
02-20-2006, 09:26 AM
Were doomed!
Chris Craft Stinger 222
while your getting this fixed, you better change your engine and trans fluids as well.....seeing that you spiked 260 the oils were geeting fried as well and breaking down.....youll have bigger problems down the road on bad fluids!
-Wally
The dollar decides how far you can go....
AOL IM: bigblockwally
02-20-2006, 10:39 AM
lucky it didn't hit hot exhaust and start a fire
Chris G.
02-20-2006, 12:51 PM
Quote:
Alright I'll mention that to them. Last time I checked, the Jeep was still sitting in the driveway waiting for a tow...I just wanna get this done with and find out much it's gonna set me back.
02-20-2006, 01:37 PM
SORE MEMBER
Kawa 1100 ZXI, SeaDoo RXP Stryker Equalizer 2800
No belt = no water pump = bad news. Likely you havn't seen all the damage yet
Mark,
02-20-2006, 02:09 PM
It's all good.
Azimut 46 / MTI 42
Quote:
Looks f@cked to my untrained eye.
If you need anymire help let me know.
