Go Back   Offshoreonly.com > General Discussion > Trucks, Trailers and Transportation
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-23-2006, 07:29 PM   #1
air suspension expedition 1998
I have a 1998 expedition that I use to tow my 260 sonic. The rear sits a little lower than I would like so I am thinking of adding an air suspension to the rear coil spring setup to level out the vehicle when towing. Has anyone installed one of these? Pros/cons costs how much trouble if you do it yourself? I have looked at the kit from Firestone anyone familiar with it?
sonicator is offline   Reply With Quote
Old 03-23-2006, 09:03 PM   #2
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
Re: air suspension expedition 1998
Firestone Ride-Rite and the Air-Lift 1000 are almost the same. I had the Airlift 1000s installed by a buddy/OSO member in Culpeper, VA on my last two trucks for about $300 w/o compressor. (I think you are in VA right?)
Shoot me a PM if I can be of more assistance. I don't see ANY cons to having the system. It basically acts as an ajustable anti-roll bar when you are not towing as well. Make sure you install with separate air fills for each side/airbag to keep from an unsafe situation of load shift/air pressure shift in a turn, etc.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
air ride suspension or air shocks? mcraymond3 Trucks, Trailers and Transportation 2 05-05-2008 09:00 PM
1998 expedition 5.4 throwing PO171 and 174 code sonicator Trucks, Trailers and Transportation 2 11-03-2007 10:32 PM
1998 expedition will not start sonicator Trucks, Trailers and Transportation 7 10-07-2007 08:34 AM
Rotors on 1998 Ford Expedition 4 X 4 sonicator Trucks, Trailers and Transportation 6 08-21-2007 03:20 PM
Air Bags for Rear Suspension? Downtown42 Trucks, Trailers and Transportation 20 12-06-2005 02:47 PM
Search Engine Optimization by vBSEO 3.2.0
