does your f250/f350 4x4 sb have a driveline vibration under accel?
Re: does your f250/f350 4x4 sb have a driveline vibration under accel?
I shimmed the center bearing about 1/2 inch and all is good.
Originally Posted by berns29scarab
i have a 1 piece drive shaft
Originally Posted by Jupiter Sunsation
The easiest fix is to BUY A DURAMAX- Vibration free from the factory!
blocks and shocks in rear, springs,shocks and all other kinds of stuff up front
I have an 06 F-250 crew cab shortbed and mine also vibrates badly when accelerating with the boat attached.
Originally Posted by ratman
i drove 3 different f250 and f350 4x4 shortbed psd srw trucks, all of them had a driveline vibration under hard acceleration from a dead stop. some were more pronounced than others. i figure it will be much worse towing a heavy load. i asume it has something to do with the 2 pc rear drive shaft. are any of you guys getting the same type of vibration. these were 2001 and 2002 model year trucks, thx for youe input, rm
