Like Tree0Likes
Replacement subwoofer for Yukon XL?
Old 11-16-2006, 04:07 PM
My Boats: '77 Hornet II
Default Replacement subwoofer for Yukon XL?
The factory (left rear bulkhead), non-Bose sub is 8" and sounds a bit worn out. Crutchfield doesn't list anything "over the counter" but I know there's got to be something I can do. Either replace the stock 8" with a new one (not factory), or figure out an enclosure that would let me squeeze a 10" in the factory space.
FWIW, stereos are at the bottom of my list of things to upgrade, so I'm not thinking of anything fancy. But between the truck needing TLC and the boat needing an upgrade, I figure I've got to look into this stuff.
Thanks,
Michael
handfulz28 is offline
Old 11-16-2006, 04:34 PM
Forum Regulator
Trade Score: (1)
Sydwayz's Avatar
My Boats: 17' Speedliner Cat & O.P.B.
Default Re: Replacement subwoofer for Yukon XL?
http://mobile.jlaudio.com/products_s...6&model_id=324
Install the stealthbox instead of the factory sub. They sound REALLY good. Some can even be ordered with an amp.
Sydwayz is offline
Old 11-16-2006, 04:53 PM
I wonder if I could mount that in the rear bulkhead, where the tire changing stuff is?
There's no way I could give up my console space.
EDIT: Hey Sydwayz, looks like I was typing while you were editing I didn't see the dimensions listed on the website. But definitely an option.
Old 11-16-2006, 05:11 PM
My Boats: Eliminator 27 Daytona
I Have A Couple Of Take Out Yukon Oem Boxes If You Need One If You Call Me You Can Have It If My Emp.did Not Chunk Them Cell Is 352-267-1143 Or Shop 352-753-jams (5267)
eliminatethis is offline
Old 11-16-2006, 05:15 PM
talked to my installer we still have one we did not throw out
Old 11-16-2006, 05:37 PM
Thanks Chris for taking the call and the quick audio lesson
I gotta figure out how good my fab/glass skills are....seeing as how I've never done it.
Old 11-17-2006, 11:39 AM
to easy just use the west pump mix system and do a little at a time you will do it in one day
Dono77056
Pantera
2
04-27-2008 10:01 AM
rockstar38
12
03-31-2008 08:22 PM
rockstar38
Cigarette
21
03-21-2008 03:52 PM
