new ford dually
Re: new ford dually
www.thedieselstop.com
I did a LOT of research on that site before I bought tweaks for my Ford PSD. I highly recommend talking to the folks that sponsor that site.
Stay away from K&N Filters on the PSD.
Location: A tree somewhere in the woods in Clarcona Fl.
Re: new ford dually
I,m on my second ford with a 6.0 powerstroke,an 04 Harley Edition F250 4x4 with a 4" lift and 365/65r16 Toyo at tires, and my present truck is an o6 F350 4x4 swb dually with a front leveling kit and 34" tall 19.5 Michelins and on both trucks I've made the exact same mods, Airaid air box, Basanni 4" exhaust(turbo back/no cat) and Edge with attitude programmer and have had no problems whatsoever with either truck, but buy a programmer that is adjustable on the fly like the Edge/Banks product, and remember to turn it down/off when towing.
Just my 2 cents worth.
Re: new ford dually
This also where I get my info. I have 4 F350's, with different chips/modules. SCT Custom tuned is the best, BY FAR, doesnt slip in higher hp applications, and thats very important if you want tranny and turbo to live. I had numerous problems with Edge after 40k miles. www.innovativediesel.com Eric/Ted...thats where to get the SCT. As to intake, I like AFE Mega 2, and you will also need a exhaust, preferabley a 3-1/2" down pipe into duals is the best performing, cools the EGT's down quickly in the hotter settings. We turn 13.7's with the CC 4x4 F250 and 14.01 was the best 2 weeks ago I got on my dually. Good Luck Jeff
The BAD Guy
Re: new ford dually
Hey Jeff I have done the research and the SCT is the way to go. Three questions? 1 Is there an easy way to turn it off if your going to tow? 2 How many miles did you put on your trucks before the SCT? 3 Did you see SCT has a new one called livewire?
Re: new ford dually
thanks for all your opinions and suggestions.
I am looking first for a winter tire wheel set up(maybe stay stock)
summer tire wheel pkg ( Larger)
does a larger wheel affect towing/ braking?
interoir and engine mod. this spring
Re: new ford dually
Yes the larger wheels affect both braking and towing. With larger wheels there's more mass, larger diameter, takes a little longer to stop. Also cuts down on your towing capacity. Once you start the mods, it seems like it's never ending. Some times I wish my truck was still stock. Sometimes.....
Re: new ford dually
[QUOTE=comp]thanks for all your opinions and suggestions.
interoir and engine mod. this spring[/Q
See my thread titled dually wheel apgrade that works. Its a very factual thread(even though I went to extremes) on the bigger tires/wheels issue. The synopsis is that bigger tires/wheels affect braking/ride/towing performance/fuel mileage, the bigger you go, the more you compromise the vehicle..I was happy with the final outcome with mine, but it damned sure cost me alot of money to get there.
Nick
Nick
Re: new ford dually
I drive 25k per year, and ususaly sell to my employees, my 03 whch is still in service has over 125k. Had Edge, but I switched it out. ( I had 6 trucks previosly with edge and went through 6 Trannys.) They have not gone through a tranny, but have had some engine work done, faulty of EARLY 6.0's. The person who has my 05, has around 60k, no problems, and he beats the crap out of it. Hope this helps. Good Luck...Cant wait till my F450 comes. Jeff
Re: new ford dually
I love the 6.0, had a 7.3 the 6.0 seems to have more power stock. 57000 miles and never had a problem. This is an 03 that I bought in late 03. Getting between 17 and 18.5 mpg depending how I drive, highway it seems the faster I go the better mileage I get.
