Whats the largest boat you can pull with an f250?
In the market for a used 28-34 foot baja or cigarette,and I just want to know what is the largest you guys have pulled with an f250
Re: Whats the largest boat you can pull with an f250?
I forget the numbers but I was within specs pulling 9,300lb boat and trailer with mine (gas)
Chris G.
Chris G.
Registered User
I would check with your Ford dealer. I was looking at a F250SD with the 5.4, and I was surprised at how low the tow capacity was vs the GVWR in the spec's in their brochure. Especially since I had already had a couple of friends tow my boat, it seemed like a good package. I ended up up buying a GMC with 6.0m that was rated for the load.
I had a F-250 4x4 crew cab last year & pulled my 43 Scarab with trips & my 42 GTX. The GTX was a little easier then the Scarab ( not a suprise ) but both where ok. You just had to watch for people stopping in front of you. It was a little short on brakes for the Scarab. By the way it had a v-10 & it wasn't has good has the 6.0 diesels I had in 05 & 04.
