'04 F350 Superduty 6.0, good choice?
The 03's and early 04's were certainly problematic. But don't discount the entire lot. Especially by the time the 05's came out (with the re-designed front end) the trucks seem much better.
and with 2,500,000 trucks out there, a 0.01% dis-satisfaction percentage would make for 25,000 un-happy Ford owners.
The VT 365 V8 (6.0 powerstroke) Has a lot of issues that are all minor but added up if ignored could be a problem.
1 The variable geometry turbo. It builds up rust and will not change positions. Easy clean up fix.
2 There is a STV fitting (quick disconnect) on the branch tube to the IC Pump gets hammered and will become uncoupled and you could loose injection oil pressure and damage the tube.
3 Head bolt stretch- A new AFC’ stitch method allows you to remove them one at a time to R&R them one at a time and not remove the head to R&R the gasket.
4 Rocker fulcrum wear- Can be replaced at the same time as above repair.
5 EGR coolers- They suck and will plug up. Also numerous head gaskets have been condemned because when the EGR cooler lets go it drips coolant down and around the head and it will look like a bad head gasket.
For the International motors the rear gear train has some issues that don’t seem to affect the Ford motors.
There have been some programming changes that have fixed the injector issues. The new program cycles the injector to dump ICP oil and will give you a little longer start up time to build up the ICP pressure but helps with the “sticktion” problem with the second generation injectors. I don’t know where ford stands on this you will need to contact the dealer.
These motors are very finicky about ELC anti freeze. The ELC mixed with tap water will turn the mineral in the water into hard beads that will pelt the head gaskets like a sand blaster. ONLY USE 50/50 PREMIX with these motors.
these are exactly the types of issues I found on the flat rate tech website. My thinking is this: this truck has 46K miles, I would put at least 40-50K miles in one year, warranty is 100K, these type of repairs could come out of my pocket.
There are some real horror stories on these engines. Research changed my mind on deciding to purchase this truck with this engine.
I am not going to take a chance at going that far negative on the operation of a truck. I am going to pass on this type of horse.
SAR
SAR
BillR
15
10-17-2007 10:55 AM
RoughKnight
19
10-24-2006 07:26 PM
jawbreakerkid
05-06-2005 09:20 PM
