Chevy duramax help in the south.
Rich, did you get a chance to check what we talked about on the fix. Later JJ
05's have a problem with the injectors i thank it is 2 and 7 the conector will come loose and not make contect you can tweek the pins in the connector and make them work for a while if that is it there as a tech bull. out for this problem
more than likely an air leak especially if it just happened after changing filter . it is a good idea to stick with ac delco on this item and make sure to lube orings before installing. you can also try to uninstall your programer or module and see what that does I have had a few in the shop where something has gone amiss in the programing .one that installs in line as opposed to a program that is downloaded into the system is more likely to cause issues
the only difference is the top insert that locats the filter media in the can, plastic vs metal. No performance or install advantage/disadvantage to either. The threads and o-ring seat are exactly the same as it is the same metal can.
all versions manufactured by Racor! GM just specs a metal insert/cap to locate the media.
