Rebuilding Tornsion Axles
Old 10-10-2008, 11:53 AM
Racer
Racer
Wahoo ATV's Avatar
Default Rebuilding Tornsion Axles
Can you replace the rubber tornsion "springs" in this axles? If so do you need to send them back to the factory?
Wahoo ATV is offline
Old 10-10-2008, 12:41 PM
I don't believe they come apart. Not really a spring, least not metallic spring, they use a rubber insert, pretty much maintenance free. What problem are you having?
happy hours is offline
Old 10-10-2008, 12:57 PM
Racer
Racer
Wahoo ATV's Avatar
they apear to be sagging. When you jack the axle up the spindle drops a few inches.
Old 10-10-2008, 03:43 PM
Rob
Strip Poker 388's Avatar
I don't think ya can,or wouldn't be cost effective sending them back,freight?I am thinking with the boat on it the arm may be around 10-11 O'Clock
heres the angle of the arm unloaded.
last pick is a brand new trailer just the trailer weight on it,
Attached Thumbnails Rebuilding Tornsion Axles-11-07-1-145.jpg   Rebuilding Tornsion Axles-11-07-1-141-large-.jpg   Rebuilding Tornsion Axles-destin-8-15-08-228-large-.jpg
Strip Poker 388 is offline
Old 10-10-2008, 06:04 PM
I had one repaired. They heated the axle to melt the old rubber so they could pull out the torsion stub. Then they compress and freeze the new rubbers. It takes a special press that uses liquid nitrogen to freeze the rubbers (4). They took the frozen assembly and simply slid it in to the end of the square tubing axle and waited for it to thaw....presto a new torsion assembly.
fossil fuel is offline
Old 10-10-2008, 06:05 PM
That looks like a Tie Down axle....good luck with the factory
Old 10-10-2008, 08:10 PM
Racer
Racer
Wahoo ATV's Avatar
thanks. I called Dexter and they said no rebuilds. New axle is around $490 bare
Old 10-10-2008, 08:27 PM
Default axels
Dean:
I have a friend that had a couple of new torsion axels and was planning on selling them. If he still has them I know he will part with them for a good price. I also have an account with dexter for axels and know I can beat that price. I will call you this weekend with the info I have. Sorry you won't be in Key West, I am working real hard to get TKO back together but I know We will be ready. Thanks for the confidence.
Charlie
whiplash22 is offline
Old 10-11-2008, 06:10 PM
Racer
Racer
Wahoo ATV's Avatar
Thanks Charlie, I will measure them up this week and give you a call.
Old 10-15-2008, 12:02 AM
Rob
that doesnt sound real bad
JPD Motorsports
6
01-15-2008 11:26 PM
pullmytrigger
7
07-06-2005 03:48 PM
MnFastBoat
6
08-02-2004 10:23 PM
MnFastBoat
6
04-18-2004 09:45 PM
euby
12
07-22-2003 08:42 AM
Quick Reply: Rebuilding Tornsion Axles
