raising chevy Z71 w/torsion bars Front end Alignment after?
The only "leveling kit" worth anything is Cognito. It is a new upper control arm, and it increases droop travel. You get it, crank your stock keys, and with longer shocks it's the best setup.
I just sold my 05 2500 with the keys cranked all the way no new UCA, and the ride is the same except where you hit a bump so big you bottom out the droop, which wasn't often even on Detroit's bad roads.
Also, turning the keys does NOT change the spring rate, it simply re-indexes the height. If you turned the keys, and the height stayed the same, that would change the pre-load and spring rate.
gm's do sag in front a little,if you just want to level a little it's Ok. Jack up front,give bolt's 5 complete turn's clockwise,drive it. Have done lot's of'em,no problem.
SeaRay Sundancer
Nope...havent noticed any additional wear. I have NOT had them apart to look, but feel still isnt any different.
Trust me, I went through all this when I bought my v-max two yrs ago....your good to crank'em till level...if you can get there.
Do an online search and buy one from a reputable retailer. Make sure it includes bumper brackets. The kit is basicly 2 inch nylon spacer and longer body bolts, and an extension for the shift linkage. Expect to pay around $500 for a good one. Nothing too complicated to install just time consuming.
