Stiff GMC dually springs... Any uggestions???
Hi guys. I am the happy owner of a 2002 GMC 3500 dually. The truck is great and I use it every day. My only wish is that it would be a little more comfortable with no load. On uneven roadsurface the car "kick" from the rear suspention.... It is extremely stiff! I know it is meant for heavy loads, but it is too stiff for cruising around in my opinion.
Question: Is it something I can do to make it more "driveable"??? (less shaking)
I heared somebody talked about some kind of shock absorbing shackle for the leaf springs??
Thanks for advices!!
Erik
Erik
Sulastic Shackles are supposed to be very helpful and I think are what you're talking about.
Also, Bilstein shocks make a huge improvement. I have them on my 08, (come with my RCD 6 in lift) and it rides way better than stock.
Dieselplace.com has a ton of info on these trucks, so I'd ask there. Just be prepared you might end up spending more than you planned on numerous other upgrades.
There is a company that makes an expandable tank that goes in the bed. It is filled with water. So when unload fill with water, when loaded empty it. It lies flat and is supposed to be very strong. I haven't seen it used but sounds like it would work. Personally you will probably get used to the ride....It is a one ton and will never ride super soft.
THANKS ALOT!! I have to test these out. The rear part of the truck "jumps" after going over some bad bridge connections. This is not safe... I will let you know when I have tested it.
Thanks,
Erik
Thanks,
Erik
Dieselplace.com has a huge thread about the jitters over expansion joints and bridges, etc.
I think there is also a cab mount fix or something that can be done under warranty. I'd check there for the details on the warranty fix to tell your dealer about it.
The factory overload spring has a very small gap between it and it's contact point. When the spring tries to compress after hitting small bumps the overload spring comes in contact with the main spring pack before it is able to absorb the bump. Several people have removed the overload spring and added air bags to keep the tow rating. I recomend the firestone bags.
What Bill said, I took my overload springs off the first week,added airbags for towing and it improved greatly.
I also ran the Michein LTX tires,I went up one size in height also. best riding dually I have been in.
