Quote:
Originally Posted by ICDEDPPL
The bags get me the towing capacity of a F 250, according to the specs the boat is 7300lbs, I`m good for 8000lbs. stock.. factory ratings are always on the safe side for warranty issues and such.
I know I`m crazy
Your insurance company doesn't care about what the airbag manufacturer says you can tow with his kit added to your 150. Nor do they care about the supercharger. If something happens on the highway and you are exceeding your tow rating, your insurance carrier will throw you under the bus.
The first time you need to make an evasive maneuver you'll be damn glad you've got a truck rated to tow (and stop) the amount of weight you're towing. And, as someone else said, use the weight listed for the boat very conservatively. A 31' powerboat with twins can easily get 9-10K lbs loaded on the trailer.
Get a 3/4 ton diesel. You may not like diesels now but you will once you tow your rig with one.
Good luck and be safe.
