Go Back   Offshoreonly.com > General Discussion > Trucks, Trailers and Transportation
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-12-2009, 09:33 PM   #1
JB Marshall
J.B. Marshall's Avatar
Formula, 382 Fastech
Trailer bearing maintenance ?
How often does everyone (well those that do) change or repack their wheel bearings?
I did mine in 2007, compete replacement of all bearings & seals and I grease them regularly, I just did a check on the wheels before the winter layup and found one of the wheels bearings completely shot and two others needing to be repacked.
I do not put a lot of miles on the trailer but do put it in and out of fresh water about 10 times a month in the summer.
J.B. Marshall is offline   Reply With Quote
Old 10-12-2009, 10:14 PM   #2
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
Personally... I grease mine and check tire pressure before every LONG road trip. Every spring I have them packed and inspected by a local semi trailer place. Just my .02 because afte purchasing the boat I was heading down the interstate at 80MPH and looked back to see a rocket of fire shooting ot of a middle tire...previous owner didn't maintain it correctly and I eded up spending 2grand redoin every hub and bearing on th whole trailer to make sure it and the brake system was right. Save yourself the big bucks by being anal retentive about preventative maintenance. As far as hold up time. Make sure and use a water resistant grease. I even step up and use synthetic Mobil grease in mine, and they are more commonly torn up from boat that make hard pivoting turns alot from my inspectons.
FuelinAround is offline   Reply With Quote
Sponsored Links
Old 10-13-2009, 12:07 PM   #3
sleek1
sleek1's Avatar
2001 Formula Fastech 353
I typically repack mine every other year. I will put a 5 pumps of grease in each hub mid summer. I boat in fresh water 2-4 times a month from March to November
sleek1 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
