Go Back   Offshoreonly.com > General Discussion > Trucks, Trailers and Transportation
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-21-2009, 10:13 AM   #1
98 Baja 232 Boss
2008 Duramax 2500 HD & Flame
I have a 2008 2wd Duramax 2500HD and possibly buying a Nordic Flame. pulling and stopping I dont think ill have a problem with but what do you guys think about at the ramp? Does anyone on here have this setup by chance?
Whistler08 is offline   Reply With Quote
Old 10-21-2009, 10:22 AM   #2
Life is good lb:)
customryder's Avatar
39 Lip-Ship Cigarette 700 Zuls
Quote:
it not be a problem..
customryder is offline   Reply With Quote
Sponsored Links
Old 10-21-2009, 10:36 AM   #3
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
See this thread:
http://www.offshoreonly.com/forums/t...n-problem.html
I've gotten my F-350 dually "stuck" (or just spinning tires) pulling my boat through a wet grass field; and been forced to lock into 4x4. No one can promise you that you will not have problem.
See my signature and keep a tow strap handy: as well as a friend with another truck when visiting ramps you don't know well.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Old 10-21-2009, 11:08 AM   #4
98 Baja 232 Boss
Exclamation
Sydwayz,
I read that forumn and commented on it also. I dont have any issues right now with spinning tires but I'm sure it helps that I have 305/55/20 Nitto Terra Graplers and only pulling a 23' Baja that ways 4300lbs. I have dropped on real steep ramps and havent had a problem yet butI'ms ure that extra weight is going to change the situation. I always carry a tow strap cause it is 2wd (wanted 4wd but couldnt pass up the deal). I'm thinking weight in the back of the truck to would possibly do the trick.
Old 10-21-2009, 11:16 AM   #5
Forum Regulator
Sydwayz's Avatar
Nothing you can do except give it a try and see what it does. As you know, rarely do you see/use a dry ramp. When retrieving the boat, normally the back of the boat is floating off the trailer as you lock in the winch strap. This is giving you a fair amount of tongue weight. As you move up the ramp, the rear of the boat will settle onto the trailer, and your tongue weight will decrease. The incline of the ramp will also slightly affect this weight transfer. Additional weight in the back of the truck may help, but it's also just going to be more weight that you have to drag around all the time decreasing mileage and adding to the sustained load on the truck counting against your weight ratings.
You may look into the water sacks that they put in the back of trucks for winter traction. This way you can drain out the water weight and add it back when you need it.
Brian T.
Old 10-21-2009, 11:30 AM   #6
98 Baja 232 Boss
Thanks for the feedback. Guess ill have to give it a try and see what happens Then ill be the one everyone is laughing at instead of looking at saying nice boat it will be should have bought a 4wd.
Old 10-21-2009, 11:51 AM   #7
Forum Regulator
Sydwayz's Avatar
Seeing a 1-tire-fire at the ramp is quite the comedy. Good luck!
Brian T.
Old 10-21-2009, 01:12 PM   #8
98 Baja 232 Boss
Ill giver her hell
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
