What do you tow with an 08 or newer Ford Expedition?
I have a 1987 35' Cafe Racer. I believe that the weight is between 9,000 - 10,000 lbs. +/-, not including the weight of the trailer. According to the tow guide, a 2WD 2007 Expedition has a 9,100 lb. tow rating. If I was looking at the tow guide correctly, it appears that a 2WD 2500 Chevy and the F-250 have tow capacities in the same ball park of the Expedition.
Really, all I need to do is get the boat home. Well, at the dry storage facility anyway. It's roughly a 60 mile trip.
1 Post
Fixx
Can it pull it? yes, my concern would be stopping and the weight rating on the hitch..also check your local dmv on your plate restrictions..a regular car plate is only good for xxx amount of weight and the local officer will give you a ticket for over weight..here in chicago i think the weight on a regular plate is 8000 pounds..also if your not using a weight distribution hitch you may be over on the hitch rating and believe me they will bend and brake..
We don't have different plates here like Chicago does. Let's see, if I remember correctly, pick-up trucks have "B" plates, right? And stay off Lake Shore Drive and Blvds. too?
I have a factory towing package, so I'd imagine that the hitch is rated for the tow rating of the vehicle, would that be a safe assumption?
As far as the braking issue, wouldn't the trailer brakes make up for any loss from the vehicle?
Thank you for the reply. I'm originally from Chicago......I miss it there. I live in Florida, but, Chicago is home. Go to Portillo's for me tonight! LOL!!
21 and 42 footers
I am not one of those guys who blow things out of proportion or get all jazzed up over Tow Capacities but WOWZER - I tow my Cafe with an F350 diesel Dually, and I can promise you it is the smallest truck I will EVER own. That cafe is 10k plus fuel, plus the trailer, plus the gear. I assume that I consistently run around in the 14k range.
That Expedition will have a hard time controlling that boat - REALLY!!!
It will have a hard time getting it going and it will have a real hard time stopping it. I would be careful, or see if there is someone on here with the right truck who would yank it for you.
I used to tow a Formula 312 with a Lincoln Navigator......similar truck to the Expedition. It had that auto leveling airbag suspension which was cool. I upgraded the factory hitch to a 15K hitch, but really......it was not a good thing. I had surge brakes....not too fun. Wasn't probably legal and if something would have happened.....probably wouldn't have been covered.
These pics will give you an idea.
