Another Diesel Shoot Out
the Duramax needs about 2,000 rpm to tow the trailer up a moderate grade. The Power Stroke conquers the same grade at the same speed at about 1,300 rpm.
They don't mention what mode the trans are in (Tow/Haul or not).
You know whats funny about ford and the new 6.7. they released the truck and the horsepower ratings. to keep the other two brands in the dark they waited until the last minute. then dodge and chevy release theirs. now, we have a re-cal for the trucks to up the horsepower and torque. ford was waitin and when they were all about even now we are re-programming the trucks for even more power! Gotta love it!
SORE MEMBER
1 Post
I can run up to 79mph in 6th at 1900rpm without hurting the economy, anything over that and watch out.
As far as the article
"In 0-60 acceleration runs with 10,000-lb. trailers supplied by GM, the Ram was outgunned badly by its rivals. And as good as the new Power Stroke is, GM’s Duramax consistently delivered the fastest times.
The Sierra Denali sprinted to 60 mph in 8.42 seconds without a trailer, 20.27 seconds with. The Super Duty needed 9.4 seconds to reach 60 mph trailer-free and 20.4 seconds with the trailer."
the numbers speak for themselves.
The Duramax is very economical below 1900 rpm, once you get over that number, it starts to make the HP and economy slips.
Ford tow/haul supplies engine braking and a different shifting strategy. the new torq-shift actually has 7 gears. only uses 6 at a time depending on temp and if in tow/haul or not.
The torque and drivability is so important. I'd gladly give up marginal speed differences for more durability and less trips to Mr. Fixxer
Those are the type of stats they never publish as shootouts.
the converter should only lock up in overdrive. the ford that they used for the testing also had 3.55 gears. and yes, i would assume with towing a 10k load all trucks were in tow/haul or whatever the other guys call it.
The article makes a point of noting the different RPMs while pulling up the grade, but doesn't explain why. I would expect the 3.55s to need the downshift moreso than the 3.73s. But I can only guess there's a difference in T/H programming/logic. Or is there that big a difference in trans ratios?
