Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: F350 Vibration
  1. #1
    Platinum Member Platinum Member seafordguy's Avatar
    My Boats:
    Cigarette - Cafe Racer
    Join Date
    Jun 2006
    Location
    Seaford, VA
    Posts
    3,567
    F350 Vibration
    Fixxxxer - hopefully you can help me out again (or anyone else).
    2000 F350 Dually 4x4 7.3. 108k on it.
    Had an occasional strange noise in the front end (grinding). Been followed up during my latest 500 miles with some occasional vibration like you are hitting grated road, or the "fall asleep strips".
    Research indicates needle bearings in the front hub assembly or possibly the occasional sticking Auto-Hub.
    Any thoughts?
    I haven't gotten to lift it up yet and shake it around to see if there is any play. To my knowledge there has been no front end work other than one ball joint on the right side.
  2. #2
    Platinum Member Platinum Member carter38's Avatar
    My Boats:
    Cigarettes
    Join Date
    Jan 2003
    Location
    Oklahoma/GLOC
    Posts
    2,440
    108k ball joints and wheel hubs. The straight axles are ball joint eating sobs.
  3. #3
    Platinum Member Platinum Member Jassman's Avatar
    Join Date
    Oct 2000
    Posts
    9,363
    Quote Originally Posted by carter38 View Post
    agree.. in 05 that changed..
  4. #4
    Registered mama tryed's Avatar
    My Boats:
    32 SUNSATION
    Join Date
    Jan 2002
    Location
    Ky. Lake
    Posts
    2,660
    Is it an Automatic?
  5. #5
    coolrunning racing VIP Member mrv8outboard's Avatar
    My Boats:
    built myself 1994
    Join Date
    Feb 2001
    Location
    cape cod
    Posts
    514
    The noise is the wheel bearing/hub assembly. Ball joints I can not believe they are any good unless they have been replaced.
  6. #6
    Registered bigboat28's Avatar
    My Boats:
    2004 31 Formula PC and a 1988 28 Pantera for sale
    Join Date
    Dec 2004
    Location
    Ohio
    Posts
    2,995
    It is the needle bearings. I just did mine. I had the same problem, felt like you were running over rough road. You can check it by turning your 4wd knob to 4wd while you are going and it is vibrating. It should stop. I replaced the needle bearings in the drivers side and the whole hub on the passenger side. This was done at 110,000 miles. My ball joints are still good.
  7. #7
    My Boats:
    Join Date
    Dec 2004
    Location
    Ohio
    Posts
    2,995
    They are a one piece assembly but you can get just the needle bearings. I got mine at carquest and the hub assembly online, supposedly it has a life time warranty.
  8. #8
    My Boats:
    Join Date
    Dec 2004
    Location
    Ohio
    Posts
    2,995
    Oh yea mine is a 2002.
  9. #9
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    17' Speedliner Cat & O.P.B.
    Join Date
    May 2001
    Location
    Worldwide
    Posts
    21,396
    I had bearings, hubs, and ball joints done on mine around 100K miles.
    If this is what you determine is wrong, let me know. My buddy in FL saved me over 50% on the bearings which were the most expensive parts.
  10. #10
    My Boats:
    Join Date
    Jun 2006
    Location
    Seaford, VA
    Posts
    3,567
    Thanks guys....
    The Pass ball Joint has been replaced. I won't replace the drivers side until it begins the tell-tale Clunk.
    I'll pull it apart next weekend and do the bearings.....
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2017 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
