2002 ford f250 ball joints
We have a fleet of 11 Super Duty trucks (all F-350 diesels) and if memory serves me correctly, the older ones have very little clearance between the upper ball joint and the axle yoke. This requires a 90 degree Zerk fitting - which can pretty easily get sheared off. The newer trucks (maybe the ones with the coil srongs?) have much more clearance. Am I correct here?
1 Post
Fixx
We have a fleet of 11 Super Duty trucks (all F-150 diesels) and if memory serves me correctly, the older ones have very little clearance between the upper ball joint and the axle yoke. This requires a 90 degree Zerk fitting - which can pretty easily get sheared off. The newer trucks (maybe the ones with the coil srongs?) have much more clearance. Am I correct here?
OK, I deserved that. Problem corrected. And now for my question?
Note to self. Never post on internet forums whilst on prescription medications for the cold from hell unless you have somebody with a BAC of less than .08 proof read post for you. Of course if you want to look like an arse …
