Trailering with full cover on the boat
Well I went and got some rope and pipe insulation for my cover to snug it down really good. The pipe insulation should keep the gelcoat protected. I am taking a 3 hour trip to the lake tommorow so I will see how it works.
I trailer with a full cover, but only with covers made specifically for trailering. I have had full trailering covers made by the same local company for several of my past boats. These things are skin tight and do not move at all in the wind! Here are some pictures.
The first is one is my current boat, a 2005 39 Top Gun.
The second picture is a 2003 Canopied Gladiator.
The third picture is a 2000 38 Top Gun.
The last picture is a 1996 28 Pantera.
Boat Cover
Duck, can you post the name and phone number of the company that makes your boat covers. I pull my boat back and forth between Florida and Ontario, sure would like to get it properly covered. Thanks
That is exactly the type of cover I need. It worked out ok this weekend but I had to really snug the cover down in the back, all over for that matter. I also had to wipe the boat down because of all the pollen and fine dust that was in the cover blew loose all over the inside of the boat. I will be trailering as normal with no cover and hoping the bugs don't get that bad this year until I get one of those one of custom covers.
Yes, it has a zipper from the bow stop down and the finish of the boat is protected from the zipper by a flap of material just like the zipper on a pair of pants. It also has a zipper across the windscreen in front of the cockpit. With that much material it is much easier to handle the cover in two pieces when it is off of the boat.
The guy that makes these covers use to work for a company called Canvas Experts, but he had a falling out with the company owner last year and now has his own company. His number is (443) 366-5825 (ask for David). He personally does everything on these covers from the initial patterns to the actual sewing to the final fitting.
The only catch is that he will need your actual boat to make the patterns. I talked to him about mass producing these covers, but he will not do it because he does not want to sacrifice the quality of the fit and finish. Not every boat is the same (even the same model of boat) and he builds reinforcement into all of the stress areas that will be covered. For example, even though two boat may be the same model, they may have different seats, different deck hardware, different hatches, different location for fuel fills, fuel tank vents, etc. He is that meticulous with his covers, but they last forever and they fit like a glove!
Duck, Thanks for the details. I'm thinking there is going to be a 10 to 11 hour drive in my future. Do you have any boating activities in your area this summer that would be worth the drive? How long I stay would be based on how long it takes to make the cover.
Nothing that I know of here in Ocean City, but check out these organizations because they host events within a few hours of here.
www.cbpba.com
www.njppc.com
www.cbpba.com
www.njppc.com
