Chevy 4x4 Trucks (Transfer Case)
Well, since the case is actually magnesium alloy and not aluminum, I'd tend to soak it with acetone a couple times and "sweat" the surface with a heat gun.
Then, JB Weld should work fine but you have to do it from the inside to properly fix it.
It's awesome that 5200 worked for you but I don't think I'll go that route. It is a cool story to hear that you sold it running with 275 on it. These things are junk - all of them.
It's sad that you see as many TSB's and recalls on something that cost so much. I'll never buy another new pickup. Chevy lost me for good and I'm sure that they will never miss me or my little budget but none-the-less...
I agree that all manufacturers make junk. After all, they are in the car SELLING business!
What makes JB weld so much better than urethane sealant? I've never seen a jB weld repair that has lasted for any significant length of time. I've used urethane sealants for years in my job and have never seen a failure.
If you don't have the resources to properly weld magnesium (special wire, skill, special fire extinguishers etc), then it's only my opinion that JB product (mixed properly) when applied to this metal is a better choice.
If you feel better with urethane than by all means stick to what you like.
I know I probably won't bother with having a welder fix the case. Also, the JB Weld can be used to take up space and attach to the saver on the inside preventing movement in the future which in turn "should" keep it from wearing another hole. Urethane won't do that.
Also, I'm unsure as to whether or not urethane will hold up and stick on a surface where the synthetic tranny oil is always trying to get out. Does it work well for oil at 200 degrees with lots of different additives?
I just never would have thought of using a below-the-waterline marine sealant on my truck. Maybe it's fine.
I've seen JB Weld do amazing things for long periods of time. Has it's place sometimes..
Magnesium actually sweats. It's a whole different animal and to correct myself one should actually tig weld the spots in question. You weld up the worn grooves on the inside and grind them down to the point where the pump will go back in.
Urethane is used as a structural component on a lot of construction sites. I only used 5200 because I didn't have any NP-1 or Sikaflex around the house. Any of which would have worked.
