Coating for Bunks
CCA is chromium copper arsenate. All pressure treated wood used to be CCA. Recently however most of what you will find is ACQ alkaline copper quaternary.
If you goto any home building material yard and get pressure treated wood it has been ACQ since at least 2004, and possibly as far back as 2002. CCA is banned as a home building material in most all situations. If your trying to find CCA lumber I wouldn't even know where to look. I do know that it is still made and used in some industries.
Paint 'em with exterior grade paint. Ask around your local hazardous waste disposal and they might give away five gallon buckets for free.
Red Wood
Point is PT lumber in a boat trailer environment (not exposed to sun and weather) should last a very loooooong time. I would use no sealer and as someone suggested wrap the carpet around the top and sides but leave the bottom as open as possible so it can still drain and dry. just my 2cents.
Weep holes
Where do you need to put the weep holes how deep etc. How old are your bunks and how are they holding up?
