How often is 4wd needed on ramps?
#31
I've had 4WD trucks for 20+ years ? ?
how? "before so prevelent"
no doubt with more ramp struggles and more duallies in front of "big boats"
not to mention "big boats" weren't so "prevelent" amongst the masses 20 years ago.
#32
I have 4 wheel drive and have for longer than I care to remember - but that's because we average 100" of snow a year. Have I ever used it in a launch ramp? Yes, maybe twice. I always get a limited slip rear axle and good technique and that will get you out 99.8% of the time. (For those of you without LS, lightly dragging the brakes or a couple of big guys bouncing on your back bumper will do wonders.)
Now for that other .2% of the time, 4WD comes in real handy. I can't tell you how many times I've dropped my trailer so I can chain up so some idiot with 2WD who has caused a real mess. Remember, once you start spinning the rear tires, you can quickly get yourself in a situation where nothing but 4WD will get you out.
#34
Location: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
1 Post
I launch in 2 since I have electric trailer brakes, but my F350 DRW won't pull it out in 2WD if the ramp is wet at all. I suppose it all depends on the ramp and what you're trying to yank out of the water. I won't own anything but a 4X4 to tow.
#35
I dunno but you all must really either pick some earl 60's -70's built p.o.s launch ramps or carry no tounge weight at all on your hitches or have giant mudders for tires. I've never come across a ramp that my properly set up 2WD tow vehicle has any kind of issue, including the steep azz wet ramp at Jamestown. Perhaps there may someday be a place I may come across to think I perhaps maybe need 4WD, but I look at it that if I need 4WD to pull it out it's probably a trashed ramp that has underwater issues that I don't want to launch from or retrieve from anyway.
Sometimes 4WD just gives idiots a false sense of security. Common sense still gies a long way's now-days.
http://www.youtube.com/watch?v=3goRf...eature=related
#36
The best part was when the guy gets out of his truck at the top of the ramp. He says, “Where’s your dad? I want to thank him because he’s a genius.” “Uh sir, my dad’s probably a little pissed right now. Maybe you should just get going and have a nice day” my son replied. That’s my boy!
#37
4WD helps a ton on steep ramps that are still slimy and wet from the previous launchers.. With that said, tons of guys pull some VERY VERY heavy rigs out of the water using 2wd Sportchassis that have zero lateral lugs on the rear tires. Highway tread only..
But almost all of them have stories to go along with those experiences..
#38
So, what happens when you can't use your trusted/favorite/usual ramp? I.e. you are 100 miles from your trailer, and you break a drive--or worse, you are taking on water; and you have to use Billy Bob's Backyard BBQ & Boatworks' gravel ramp with 2x8s laid across it--ramp?
Be prepared. I don't leave home without it.
So you MUST of saw me last year- Fun run WAY up river at LOTO by Rons. One drive down, on the gravel ramp under the bridge!!
If only 2WD never would have made it!
#39
