electric/hydraulic brake issue???
#105
I just picked the trailer up Fri from a 1st class repair truck & trailer place in Boyne Falls! I believe I have brakes ladies & germs!!! they found multiple leaks, bad parts, brake lines that should have flanges on it & did not!!! they replaced all 3 t fiitings, bad internal seals, replaced the 3 hoses, said they just could not stop them from leaking! Also found out from Titan the component supplier that the 2 electronic boxes/controllers at the front of the trailer R not 2 B submerged or heavily wetted, guess what!! mine get nailed heavily nearly evertime I launch!! they were mounted 2 far back & 2 low inside the c channel!! hopefully a new set on the way!! guess my trailer was built on Friday afternoon!! Nobody is perfect but it's how they thru me under the bus say'n it was my truck!! my last conversation w/ them a couple months ago was our trailer is right, it's your truck, go deal w/ NT!!! so that's what I have been do'n & they have been helpfull!!! Thanx NT
#106
The BAD Guy
#108
Glad you got a solution, in the future though, couldn't someone simply put a pressure gauge directly dead heading the pump, then moving it down the line to find the ultimate problem whether it was pressure or build up time? Too bad the trailer was on grass or your problem would have been noticed much easier.
#109
Myco should have taken care of this. How much longer till he would have had no brakes, on this brand new trailer???
Send them the bill for repair and troubles!
