Trailer Up Lighting
[ATTACH=CONFIG]526211[/ATTACH][ATTACH=CONFIG]526212[/ATTACH][ATTACH=CONFIG]526213[/ATTACH][ATTACH=CONFIG]526214[/ATTACH][ATTACH=CONFIG]526215[/ATTACH]They are flush mounted LED side marker lights. There are14 on lights on the inside of the trailer - I think they’re Optronics. I bought the boat & trailer off the owner of Phoenix Trailers. He built it with the lights and about every option available including matching graphics from Mitcher T. He used it on the cover of his brochure. I did recently remove the drive guard since it was causing me grief going up my lane at the lake. Then it ate a prop and I decided it had to go!
The flush lights would he easy to install on a tube style trailer if you have access to a plasma cutter.
I did mine last season. It helps ALOT when loading at night. I used waterproof 5050 SMD in white. They are wired to trailer running lights through a cheap float switch that I mounted on the rear part of the trailer. Back trailer in the water, and lights come on automatically - but only when running lights are energized. Pull trailer out, and lights shut off automatically.
[ATTACH=CONFIG]526363[/ATTACH]
[ATTACH=CONFIG]526364[/ATTACH]
