When your 6.0L Ford blows up; be careful loading it on the trailer. (video fail)
DRW truck. Can't fault that.
Take a second to guess the fail before you push play. I'll pretty much guarantee that you guess wrong. I didn't see it coming either.
http://youtu.be/mrn3Yb3L_iU?t=8s
You can clearly see from the video still what happens. Ouch.
I am so glad someone posted that...................so hopefully I will remember that and NOT TRY IT!
It did seem like a good idea, I would suspect that is going to be totaled due to the frame damage. Videos like this make you realize exactly how cheap a tow can be! (Cheap and worth it in the long run)
"Now what do we do?"
Well, for starters... set the parking brake on the dually and pull the trailer out from under it. You know, the small pedal way over on the left that you should have used on the 7.3L in front?
