Towing with Chevy 2500hd
#32
Anyone do a srw to drw swap on 2005 chevy 2500hd. I was just wondering which way to do it with the spacers in the rear or actually getting a used axle for the truck
#35
I am looking for more stability than anything don't want a long bed cause where I live is very tight getting it I. The driveway to store the truck right now barely makes the turn.
#36
#37
Was the dually you used to move the boat longer than your truck? If so, the added wheelbase is what added a lot of that stability.
Ford made short bed DRW trucks for many years. Your simplest fix would be to sell your truck and buy one of the Fords.
If you do the conversion to your truck, you are going to be married to it for life.
http://www.duallyfendersfiberglasstruck.com/
Scroll 3/4 of the way down on that page, and you will see a short bed GM converted to DRW.
Quick pic link:
#38
I used a reg cab drw to move it. I am thinking about the arrowcraft spacers for the rear axle and factory adapters for the from anyone see an issue with this. Also when the time comes to sell if it's an issue I will remove the conversion and then sell. I already tried a set of larger wheels 20 in and did not see or notice much improvement
Buying a differnt truck now is not an option as I am in the process if building a new house
Let me know what you think
