Ford fuel pump
Everything is disconnected, the pump will not budge, and I can't see why. Feels like maybe a metal ring inside, but my wrist only bends so much. The new pump seems to have a couple pinch clamps built in which I can feel but pinching seems to have no effect whatsoever.
Well I just checked again, are the 3 rubber feet glued in ? Thats the only thing that appears to be holding it in. I really don't want to break the tank.
After a lengthy Google search it seems you must pinch tabs while pushing down and twist to release the pump.you would think they might mention this somewhere.
1 Post
buck,,when all else fails go to youtube..theirs a bunch of info on their..push pull twist take a phuckin hammer to it ..then ak57 triple barrel heat sinking laser guided shotgun it..
I lost the original fuel pump last summer in my chevy gas dually. Had to get it towed to my house. Tow truck dropped it at 2pm. We went to parts store, got pump came back, dropped tank, replaced pump, and had it all back together by 5pm.
When getting ready to drop the tank, I got out the compressor, air tools, PB blaster, etc. My buddy was already under the truck, as I was about to hand him the air tools and hose. He's like, "hold off on that, let me see that 3/8 ratchet with a 15mm socket". Dik. Bolts holding the straps came right loose, no problem. I love southern trucks.
Yes mt , i was amazed I sprayed all the bolts a couple hours ahead of time while I got sockets wrenches etc. Not sure what they are coated with, but the threads were clean on the strap bolts.
dropped it easy enough but couldn't get the fill tube to let go of death grip it had on the hose, so I ended up up fumbling blindly in tank wound up just breaking the keeper tab off to get the pump out and a bunch of dents in my head.lol At least all went back together easier than I expected.
