Manning trailers 40 foot and up, who all has one or had one???
The after sale support, issues, endurance is where I'm going with this thread too. I have a Manning under my 419 FASTech. It was built in 05 but now it concerns me about adequate support in the rear under the triples. I'm checking and fishing to learn more too.
Thanks for the replies and messages. My Manning pulls great, handles well and seems like a good trailer but the rear under the triples does not seem to have adequate support, as I see the trailer, and I'm wondering what this is all about. I have emailed them pics and questions about the trailer and what I can do.
I had manning build me a C channel aluminum for my 33 Sutphen
They were great to work with, I just gave them all my dimensions and it fit like a glove when the boat went on.
Great quality & value planning to use them again in the future, I highly recommend them?
I am in process of buying a boat with a 1999 Manning Steel trailer under her. It is a well built beast looks to me however I wish the owner would have kept up on mechanical maintenance on it. Pretty sure I need to replace bearings and brakes for peace of mind. However the trailer looks to have original paint and very minimal rust.
Location: Solomons Island, MD, Vero Beach and Punta Gorda, FL
Purchased new in 2012 for 42' Cigarette and new in 2014 for 32' Fountain CC. Easy build. Pay attention to options (galvanized axles, SS calipers, EOH brakes etc). No issues so far with a lot of towing to Florida and back. Didn't like aluminum wheels corroding in center section of wheel (drill 1/8" holes in center cap to loose salt water when moving....helps).
Do you have any pictures of your concern areas?
I have a 97 under my 35 , been flawless , except ,the bunks are screwed thru wood to metal upright and the bunks wear and compress the screws did not give after launching boat one day noticed a pile of white powder it gouged the bottom on the boat .I replaced the bunks with treated wood and did not wrap carpet around the bottom, so it can dry , also used carriage bolts so as bunks wear and compress you just tighten the nuts on bottom. but its an old trailer
Just purchased a used boat with a Manning trailer under it. Had to cut off and extend two main support posts as there was an inch gap between the bunk and the boat! I did call and verify that it was the correct trailer for the boat. Also, am in the process right now of extending the tongue of the trailer, what a bad design in my opinion to have the winch post directly above the coupler! Just a few things I have noticed so far, hopefully everything else will be fine from here out. Oh BTW, also ordered the rubber D blocks to replace the carpeted bow stops, they leave a pretty good scuff on the boat after trailering any distance.
I'll second that. I bought one just after Sommer for my 31 Sonic and I couldn't be more satisfied.
