7000lb Dexter EZ-Lube Cap Issues
Trailer hubs have lousy tolerances The chinese guy fell asleep that day when the cnc lathe was cutting the bore. Locktite red or even some JB weld should firmly hold them in. I found that if I had the slightest amount of moisture in the hub grease that It would expand way faster than clean grease. Sometimes the rubbers pushing out would tell me to change the grease. All the trips across the US to Fla never had a bearing failure.
