2017 Ford Dually with 4:10 gear
Can you run it at a stock ht with this set up or is 5" lift a low as it will go.
I ran the numbers a while back and I believe a 37" tire with 4:10 is equilavent to 3:73 with stock tires, which was surprising to me. I am sure these new motors can pull whatever you put under them. But I think this is also the set up I would want.
I forgot to mention Rob Freeman, that is one sweet looking Ford you got there. I'm a "Bow Tie till I die" guy but I do like the new '17 Fords. If the new trucks weren't so crazy expensive, I'd be looking at trading my old reliable '08!
Both ok your trucks look great! I'm considering a DRW next but a have a couple quick questions that maybe you can answer regarding lifting these things...
Do you have much trouble with stone chips with the rear wheels sticking out so much? Does anyone make a wheel offset that would keep them inward an inch or two?
