Bearing grease
What's the best grease to use when re-packing trailer wheel bearings?......
Originally Posted by scippy
(Post 4557770)
Personally, I use Kendall L-427, Super Blu. Some other comparable choices: - Conoco / Phillips - Multiplex RED #2 - Citgo - Lithoplex MP #2, Lithoplex CM #2 - Exxon/Mobil - Ronex MP, Mobilith AW2, Mobil I Synthetic Grease - Pennzoil / Quaker State - Synthetic Red Grease - Shell - Rotella Heavy Duty Lithium Complex #2 - Chevron / Texaco - Chevron Ulti-Plex Grease EP #2, Texaco Starplex Moly MPGM #2 - Valvoline - Multipurpose GM, Valvoline Durablend And do yourself a favor, get one of these if you don't have one. https://www.etrailer.com/Tools/Power...ALL648594.html |
That is a slick little tool. Almost makes me want to resume packing my own wheel be rings. LOL I have been lazy the last few years and have hired it done.
Padraig |
Originally Posted by Padraig
(Post 4557871)
Padraig |
You are going to get many responses on recommendations. Just use a quality grease and repack often.
I have been using evinrude grease for the last 5 years with no failures. https://www.amazon.com/Johnson-Evinr.../dp/B00KY540WA Whatever grease you decide to run, just make sure you don't mix grease's. I also have the wheel bearing packer above. I bought it at harbor freight. I want to say it was $10-15. |
Thanks for all the great information & suggestions!
For the money I like the Schaeffer's Aluminum complex moly ultra. Anything lithium based can "wash out" because the base thickener is soap.
Originally Posted by TylerBurich
(Post 4558027)
Perfect timing for this as I pulled a seal to grease and had milkshake in a hub. Gotta do atleast one at this point. Thanks for the above info!
(Post 4558027)
Schaeffer Manufacturing Co. 02212-029S Moly Ultra Grease NLGI #2, 14 oz. Schaeffer Manufacturing Co Link: http://a.co/goKyckj I ask because if you scroll down it looks like they offer a handful of other types too. |
