Go Back   Offshoreonly.com > General Discussion > Trucks, Trailers and Transportation
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-18-2005, 01:26 PM   #21
S.O.B (single O/B) now
t500hps's Avatar
Re: Do I have enough truck?
Quote:
Originally Posted by 43Thunder
Four wheel drive low. I never said he was smart just rich.
My dad had a 99 1500 Dodge with the 360CI motor. Motor was fine, Tranny dropped after 51,000 miles. We sold it at 49,500 and truely didn't know it had a problem. All he ever towed was a 20 ft bassboat.
Later found out that Dodge had alot of problems with the trannies in those.
t500hps is offline   Reply With Quote
Old 03-18-2005, 01:31 PM   #22
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
Quote:
Originally Posted by ScarabScoundroul
Screw dually!!!
I have a 2500 HD and my boat weighs 10,000# Single rear wheels. Pulls it just fine. In fact, I pulled the same boat with my brothers dually, duramax, crew cab and there was hardly a difference in ride comfort. Both trucks would bottom out on the bumps. So this year I added air bags to the rear. Should solve the problem. You'll be fine as long as you stick with the original 10 ply tires. (Load Range E), and keep them pumped up to 80 psi, or whatever it says on the sidewall.
He is pulling a HUGE cat, with a lot more outboard weight than your straight-line COG V-bottom.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Sponsored Links
Old 03-18-2005, 05:19 PM   #23
articfriends's Avatar
272 baja/99 mph so far/1000 plus hp
Really depends on distance,yea sure,if your running all over country to poker runs a dually would be nice but to run down to local lake would be a waste. As far as traction on a boat launch,my last dually spun the wheels easier than any single tire truck ive ever had,ended up putting a detroit locker in it. I would consider 4wd more important than dual wheels for pulling boats out of launch,Smitty
articfriends is offline   Reply With Quote
Old 03-18-2005, 05:40 PM   #24
1999 Chris Craft, 1999 Trophy CC
I bid 11000 on your current truck. -)
happy hours is offline   Reply With Quote
Old 03-19-2005, 12:14 AM   #25
GLH
It's all good.
GLH's Avatar
Azimut 46 / MTI 42
Quote:
Originally Posted by GLH
Dually
Got one today!!!!
GLH is offline   Reply With Quote
Old 03-19-2005, 12:23 AM   #26
offshoredrillin's Avatar
00 Cig Tiger,74 Cig 20'
Congrats GL, thats a pretty one!
offshoredrillin is offline   Reply With Quote
Old 03-19-2005, 12:52 AM   #27
GLH
It's all good.
GLH's Avatar
Azimut 46 / MTI 42
Blahhhh, Blahhhhh, Blahhhhh.
Cigarette+ 1 ton GM ... As close to an Elle Mc. BJ, a Big Mac with Diet Coke and fries on a hangover you can get.
Think about it!!!!
Old 03-19-2005, 04:12 AM   #28
UNOBTAINIUM MEMBER
thunderusone's Avatar
37 Outerlimits
Got one today!!!!
You need to get rid of the cheap cheasy door handles and get the Escalade versions and paint to match. Here is a pic of mine.
Sending a letter from my Banker to Enough 4 Play!
thunderusone is offline   Reply With Quote
Old 03-20-2005, 09:30 AM   #29
Chuck's Avatar
2008 Nor-Tech 36SuperCat Sold
Thanks for the bids guys, and all the recomendations. I think I'm going to shop for a dually this week. There is going to be some great incentives after all the bad news this week on the new truck and suv all over the airwaves. The hit on the 2500 shouldn't be that bad though, they are still bringing 31 to 33.5 at the auctions. Some of you bidders may have to go just a little higher . Help a brutha out!!!!
Chuck is offline   Reply With Quote
Old 03-20-2005, 10:54 AM   #30
mikes280's Avatar
velocity
hell i will go 25000 that should shut the rest of them up
mikes280 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
4x2 Truck, how big of boat do you pull? Truck size, boat size? nova26 Trucks, Trailers and Transportation 41 07-07-2008 07:10 PM
Check out this service truck! CMT TRICK MY TRUCK! THEJOKER Trucks, Trailers and Transportation 33 12-19-2007 10:09 AM
Armored Truck - Cash Truck bouyhunter Trucks, Trailers and Transportation 26 11-12-2006 02:47 PM
4x4 truck or 2x4 truck to pull with????????? PWRCAT Trucks, Trailers and Transportation 16 06-01-2005 06:47 PM
My truck will beat up your truck!!!! PhantomChaos General Boating Discussion 13 04-23-2003 01:37 AM
Search Engine Optimization by vBSEO 3.2.0
