Prop Blowout on twin Outboard
#31
It left here last spring with brand new triple Opti's on it! I had the boat out once and it ran good! A little transom heavy but pulled like a drag boat! Had to use the 30" tabs to keep it in check!
#32
#33
Thanks for the info Pepper! Cowisl I will call Bblades.
#34
I am running twin 280s' on a porta bracket if this info helps. Any advice would be appreciated. Thanks Bob.[/QUOTE]
How does it run with the 280's compared to the 260's? Mercury does a lot of R&D with Velocity hulls! I would contact them as well as Bret at BBlades. I think you will find a through hub will be best all around.
#35
#37
