X dimension on a 41 >
X dimension on a 41
X dimension on a 41
Old 01-05-2010, 11:09 AM
sl
I think for the boat, power and setup 10-12% is the mark we are shooting for. Always trade offs between top end, coming on plane and mid range acceleration. The big question is how much time and money do I want to spend in trying to hit the mark
sl is offline
Old 01-05-2010, 01:12 PM
what #'s are you hitting now , with how much power . What gain are you looking for , are there any other mods you are thinking about doing ?
notda1 is offline
Old 01-05-2010, 03:25 PM
sl
Whippled 525's dyno'd at 775 HP/790 ftlbs torque each spinning 5600-5700 rpm's. Drives are 1.5 ratio. Theoretical speed would be between 113-115 mph. With noted slip ratio should be around 100-103 mph. First time out ran 94. Couldn't do any triming on the boat because it would hit the rev limiters. As a result bow was riding lower than it should. Adding 1" spacers and changing props should make significant difference. Not really planning on changes beyond that - at least at this point.
sl is offline
Old 01-06-2010, 10:55 AM
That boat should see big #'s , I am looking forward to seeing what prop is selected . My staggard 41 needs more bow lift and I am going to try raked wheels in the spring . I run those same #'s ( 5700-5800 ) with a set of re-worked 30 4 blades . Also have some standard 33" 4 blade same top end at 5500 . Hope to get some bow lift and loosen things up , expecting to be at around 100 when I'm done .
notda1 is offline
Old 09-28-2010, 10:53 PM
Mr Velocity - if you're still around clear you PM box so I can send you a msg.
Joe308 is offline
Black Wishbone
Sutphen
4
03-11-2008 07:02 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
375stinger
Cigarette
0
11-10-2004 04:56 PM
Bajaforce
Baja
2
03-05-2003 08:09 AM
sambryce
5
03-04-2002 05:27 PM
Quick Reply: X dimension on a 41
