Go Back   Offshoreonly.com > Owner's Forum > Velocity
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 04-21-2008, 12:03 AM   #1
2000 Velocity 280
280 prop and rpm question
Got to splash my 2000 280 454mpi 385 hp for the first time. The guy I bought it from has a bravo 24 on it. says it runs the best with it. Also have the original 26 hydro. At 50 mph I'm doing 5000 rpms. I know the rpm range is 4600 - 5000. at full throttle it will go up to 5800 rpms. Called the previous owner and he said it runs at 5500 rpms and the dealer said it's ok there. Shouldn't the rev limiter kick in or is my gauge wrong. Haven't tried the original one yet.
Hotdog1922 is offline   Reply With Quote
Old 04-21-2008, 12:28 PM   #2
Velocity 390 and Velocity 220
Guage problem - if it's Faria guage there is a setting to select a 4, 6 or 8 cylinder engine. I'd check this first. Good luck.
Revelocity is offline   Reply With Quote
Sponsored Links
Old 04-21-2008, 12:40 PM   #3
1999 280 Velocity
Likely the gauge.
Rev limit is 5150 or 5200rpm.
Patrick
Pat McPherson is offline   Reply With Quote
Old 04-21-2008, 06:16 PM   #4
Velocity 280
A 24 inch Bravo may be too little prop. Try the 26 Hydro.
Padraig is offline   Reply With Quote
Old 04-21-2008, 06:54 PM   #5
2000 Velocity 280
I think the Hydro is a 25. Tried putting it on but I guess I was missing a washer for it. Didn't know it was a different hub from the Bravo.
Old 04-22-2008, 10:10 AM   #6
1999 280 Velocity
I've been told that a 26p B1 will be the best overall prop for my 502 Mag powered 280 Vel.
Patrick
Old 05-11-2008, 09:26 PM   #7
2000 Velocity 280
Put the stock 25 Hydro back on today. Took longer to plane but once I got going tached out at 5400 and only hit 56 MPH. Was wondering the previous owner had wacked his lower unit and had the skeg repaired and siad they put new parts in. Is it possible they might of changed the gear ratio? Checked the back of the tach and it is set to 8 cylinder.
Old 05-12-2008, 09:54 AM   #8
Velocity 280
Are your speeds from a GPS or the speedo???
Old 05-12-2008, 09:56 AM   #9
2000 Velocity 280
speedo
Old 05-12-2008, 12:08 PM   #10
21' Paramount
Quote:
Originally Posted by Hotdog1922 View Post
speedo
Use a gps. you may be going 68mph and not even know it. Otherwise, you've got bigger problems than the prop.
Shore Thing is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
prop rpm vs engine rpm are they the same Velocity Vector Prop Talk 3 01-28-2008 01:29 PM
prop size/rpm question bezdikjack General Q & A 3 06-23-2005 09:20 PM
Prop-RPM Question OldSchool General Boating Discussion 5 10-11-2004 12:16 AM
87 Baja Force 280 Which Prop and What RPM. Leathl_WS6 General Q & A 10 06-12-2003 10:46 PM
Prop RPM VS. Engine RPM? THRILLSEEKER General Q & A 4 08-08-2002 07:50 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
