Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-04-2009, 08:10 AM   #1
qaberdeen's Avatar
1989 Twin Merc Velocity & 2001 velocity 260
Do I Need to run a Fuel Regulator
Problem is,
My fuel regulator is showing full pressure on my guage, was . i had a little mishap over the weekend. basically my serpentine belt decided to give way and somehow something might had hit the regulator, and now is not working. when i turn the key the pressure goes from 0 to 15psi. it is also linking gas around the set screw/allen key.
hopefully i have this right, when i wind the allen key screw in am i increasing the pressure or decreasing it. i was by myself with little time to spare so i did not have time to play around with it. my engine is a carb engine and it requires a min. of 6 psi's, and it was set at 6psi's, right now i took the fuel regulator off and i have the fuel pump out line running to the carb instead of the fuel regulator than carb.
also i running the holly blue pump, is it pre set at 7psi's not sure and it runs abit warm is this normal. i also started the motor with out the fuel rugulator and it seem to run fine on the trailer..
any suggestions or info will be gladly appreaciated..
thanks Q
qaberdeen is offline   Reply With Quote
Old 08-04-2009, 10:18 AM   #2
2001 Velocity 260
it is my understanding a regulator is needed..
BUT
you might want to re-post this in the general section. You will get an answer very quickly from people far more knowledgeable then me
JohnSchiavarelli is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
