Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-05-2009, 10:10 PM   #1
qaberdeen's Avatar
1989 Twin Merc Velocity & 2001 velocity 260
Drive Indicator Not working
Need help with my Drive Indicator on my Dash,
Ever since i installed the new engine The Drive Indicator on the Dash is not working, i checked the wires behind the gauges and everything looked fine. The drive works, but i would like to know where my drive is when i driving, what should i be looking for , and where should i look..
thanks Q
qaberdeen is offline   Reply With Quote
Old 09-06-2009, 08:38 AM   #2
ls1nova's Avatar
33 Powerplay
Is it an electric guage or mechanical indicator?
ls1nova is offline   Reply With Quote
Sponsored Links
Old 09-06-2009, 08:40 AM   #3
ls1nova's Avatar
33 Powerplay
I'm guessing it's electric and you forgot to plug in the 2 wires that go from the transom assembly to the back of the motor.
Old 09-07-2009, 07:20 PM   #4
qaberdeen's Avatar
Thanks,
This i probally a silly question
But i would i know if it's electric or mechanical
Old 06-08-2010, 09:59 AM   #5
qaberdeen's Avatar
Still haven't sorted this out..what colors or what would i be looking for as fas the the two wires coming off the transome assemby, and where do they plug into..
Old 06-09-2010, 09:31 AM   #6
Revelocity's Avatar
Velocity 390 and Velocity 220
It's a pair of black wires coming through the transom plate assembly. One should go to a ground circuit and the other should be connected to a brown/white wire that goes to the trim gauge. Hopefully it's a wiring issue in the engine compartment or the guage opposed to replacing the sending unit. You can do a resistance test on the sender to check it out as it resistance will change with the drive position. Good luck.
Revelocity is offline   Reply With Quote
Old 06-09-2010, 01:12 PM   #7
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
I had to replace my cables on mine. They had stiffened up opver the years and would get stuck.
*ISN'T IT FUNNY THAT WAR AND LOSS OF JOBS BUILT SOME OF OUR MOST BEAUITFUL LAKE REGIONS?*
FuelinAround is offline   Reply With Quote
Old 06-09-2010, 07:48 PM   #8
qaberdeen's Avatar
i just checked the wiring behind the guage so it looks like it is an electrical guage..n if it's the sender, that means dropping the drive..:-(
Old 06-10-2010, 11:17 AM   #9
Revelocity's Avatar
Quote:
Correct - plus it's no easy feat feeding the two wires through the transom assembly.
Old 06-13-2010, 09:03 PM   #10
qaberdeen's Avatar
fellas,
i think i found the problem.. i found two wires coming out of the transome plate that r not connected..they look both to be black, with each having two leads on them..but i'm not sure where they plug into.. i went from an efi to a carb motor, so i'm not sure why the engine installer did not connect them..maybe one goes to the guage and the other ?..i will take some pisc tomorrow and post them..
thanks Q
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
