Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-06-2009, 08:04 AM   #11
Quote:
Originally Posted by jdcorbitt3 View Post
The Engine is in. The x dimension is 5 1/2 in higher than my old one. They are having to raise the engine cover to accomodate the engine. The nice thing is it is easy to get to the bilge. I will try to post photos.
John
5 1/2 HIGHER??!!! Now I'm interested, what year was your old boat and what actually is the x dem of the old and the new boat? I'm really interested to hear how this boat handles and what kind of speed you get. Sounds like its going to be a fun boat, I'm jealous!
DisturbedVelo22 is offline   Reply With Quote
Old 10-06-2009, 10:50 AM   #12
Pat McPherson's Avatar
1999 280 Velocity
John
John, do you meen the propshaft is going to be 5-1/2" higher?
The "X" dim is the distance from the bottom of the boat to the crank shaft of the engine/drive shaft of the outdrive.
Are you using a shorter than standard drive?
If the engine is really being raised 5-1/2" vs. the old boat, I hope that does not screw with the CG of the boat. I general you want the engine mounted as deep as possible / as close to the water as possible for best handling...
I could see using a drive that is 2 or 3" shorter and raising the engine 2 or 3" not 5-1/2", but I guess Steve knows his boats better...
Patrick
Pat McPherson is offline   Reply With Quote
Sponsored Links
Old 10-06-2009, 02:18 PM   #13
sl
John, I was at the factory last week - saw your boat. Looks great! That's going to be one crazy ride. It looks like your use of an ITS and sportmaster gives additional flexibility in the X dim. Can't wait to hear what kind of speed you get. Steve
sl is offline   Reply With Quote
Old 10-09-2009, 12:36 PM   #14
1999 280 Velocity
John,
I guess this is your old boat...
http://forums.screamandfly.com/forum...d.php?t=199042
I like these 22s...
Hey DKerns,
Are you sure you don't want to trade yours in on my boat?
Patrick
Old 10-09-2009, 05:33 PM   #15
jdcorbitt3's Avatar
2010,Velocity,22
Quote:
Originally Posted by Pat McPherson View Post
John,
I like these 22s...
Hey DKerns,
That's it
jdcorbitt3 is offline   Reply With Quote
Old 10-09-2009, 05:42 PM   #16
jdcorbitt3's Avatar
2010,Velocity,22
Quote:
Originally Posted by modvp View Post
Yeah, post some pictures of your windshield. I was looking to replace my broken windshield on my 2004 Velocity 220 and Steve said that they are now using a newer version on a 22 thats being built since the company who made the original version has folded. That was probably your boat he was referring to.
The windshield is supposed to in next week.
I don't have the actual X-dimension, but it is high. the top of the outdrive is at the base of the cap. There is all kinds of room under the engine. They were debating wheather to run the exhaust through the transem or the cap since it is so high. I would say the prop is going to be about 5 inches higher than my old boat. It is also going to be about 7 inches further aft due to the ITS drive.
The tabs are 380s. they may cut some off when they are propping the boat. The tabs are longer than what I had on a Victory 33. My old Velocity 22 didn't have or need tabs.
John
Old 10-09-2009, 10:56 PM   #17
jdcorbitt3's Avatar
2010,Velocity,22
Pics
I think I figured a way to post pics.
http://www.rx8club.com/showthread.ph...00#post3271000
This is a link to another sight.
It worked.
Old 10-10-2009, 08:12 AM   #18
It worked.
HOLY MOTHER! Ok thats alot higher than mine.
Old 10-10-2009, 02:14 PM   #19
Crazy Energy
Velocity Vector's Avatar
35'Ocean Express Cat
I know you are excited to shove sticks
The true measure of a man is how he treats someone who can do him absolutely no good.
Velocity Vector is offline   Reply With Quote
Old 10-10-2009, 09:40 PM   #20
Quote:
I was going to correct you and say stick since its a single but then I realized what that sounded like.
That ITS definitely is thicker on top, meaning the mounting looks higher than mine even if the x dem was the same height but that x is probably a good 3 to 4 inches higher than mine. Have they talked about prop selection with you? I have to imagine they're planning on going with a five blade on that boat. I'm really interested on how this boat is going to plane/handle. Also those tabs seem way too long for that boat, but I'm sure stepp knows his stuff. Would you tell them to hurry up with that thing!?
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
