Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-14-2009, 09:28 PM   #1
1987 30 Velocity 1600hp almost 100mph
Took the 30 for a test drive
On saturday I took the old 30 footer for a blast. I have 5 hrs on the engines and they are broken in. Tried my 30p rotating in, acceleration from 40 to 75 in about two seconds. Props way too small. Got a set of 32's 3000rpm 46mph 3500-55mph raced a 32 Sunsation Dominator with 502's and vortec blowers hit 89mph @ 5600 mph and 2psi boost and passed him slowly. Holly crap this boat is a drivers boat. At 80 mph I hit the tabs, bad idea, chine walked like a mother. Pulled the throttles back to half stuck the tabs down and pinned it again. I need more prop, a set of 34's, and more seat time or I will get bit hard. This boat will definatly go over 100 with more seat time. One thing I do notice is that at a fast cruse 50-60 if I hit even a small 3 footer the props will cavitate and loose there grip for a few seconds then hook up. I need to know the Xdimension and where to properly mesure it from. The boat originally came with speedy 2's I have TRS and I think that they are shorter.
Andy is offline   Reply With Quote
Old 09-14-2009, 10:43 PM   #2
Velocity 280
Sounds like you had a grand time.
You might want to call the factory and talk with Steve about x dimension etc. I have always found him willing to help.
Padraig is offline   Reply With Quote
Sponsored Links
Old 09-14-2009, 11:16 PM   #3
Crazy Energy
Velocity Vector's Avatar
35'Ocean Express Cat
Glad to see you out ripping up water Andy...My 34's are ready to ship. "X" dimension is the distance "on" the transome from the intersection of the boat bottom and transom ( drive location) to crank center to place the prop shafts at the desired heights.
This "X" dimension ends up being the "measurement" as you have to draw a line extending your running surface and then measure straight down from the crank centerline until the two lines intersect. "X-dimension" and "Prop-shaft height" are not the same thing.
Center line to prop shaft center line when trimmed parallel with the extended hull keel line and measured at right angle to that keel line. (not along the slanted transom) Prop shaft height (which is the dimension that most prop builders want to know in order to set you up with the right prop) is the distance, again measured at right angle, from the extended hull keel line to prop shaft center line, and again trimmed parallel. Don't make me come up there....
The true measure of a man is how he treats someone who can do him absolutely no good.
Velocity Vector is offline   Reply With Quote
Old 09-15-2009, 08:35 AM   #4
notd1
30' Velocity w/750's , 41' Velocity w/900's , 42' Fountain w/900's , 42' MTI
the trs and #2's are different lengths , I think #2's are longer , but not sure how much
notda1 is offline   Reply With Quote
Old 09-15-2009, 09:47 AM   #5
excalibur82
excalibur82's Avatar
10 meter fountain
the number 2's are 2 inches long than the trs.
excalibur82 is offline   Reply With Quote
Old 09-15-2009, 02:37 PM   #6
Pat McPherson's Avatar
1999 280 Velocity
If you spin the props out, the boat will likely be more stable.
I know that requires swapping the drives, but...
Sounds like a vary fun ride...
Be safe!
Patrick
Pat McPherson is offline   Reply With Quote
Old 09-15-2009, 06:23 PM   #7
notd1
If the difference is 2" , can't you just add spacers to the drives to get the right height ? Also not sure how prop diameter affects the formula . In my old 30 I was told not to run over 16" and stay with 3 blades or it would affect the way it handled . I ran 3 blade 32's on #3's with props turning in and they had a very low slip factor
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
