Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-31-2009, 10:38 AM   #21
Velocity 280
Jon, have fun putting it together and please update us with pictures etc.
Padraig is offline   Reply With Quote
Old 10-31-2009, 11:21 AM   #22
notd1
30' Velocity w/750's , 41' Velocity w/900's , 42' Fountain w/900's , 42' MTI
I would not suggest putting more than about 650hp if you are going with a bravo . Should be able to keep the motor and drive together easier that way . Looking at the numbers posted here seems you could make it work well with a lot less . Like it was said about projects before , this way you know what you really have . Mine was a project , had great results . Took longer and cost more than expected but , it was worth it !!!!!! Hope you have good luck
notda1 is offline   Reply With Quote
Sponsored Links
Old 10-31-2009, 01:19 PM   #23
2003 Velocity VR-1
Thanks Guy's will keep you updated on progress.
The boat was originally fitted with a 575sc, ITS and XR drive but i will probably be looking at a 496HO, ITS and XR drive to start with. Good used motors are very thin on the ground in the UK so may go for a new package for reliability and warranty. Later i would like to get another motor and build it to 600hp.
Really interested in high cruise speed and reliability as i live on the south coast of England, 60 miles across the water from France which is good for day trips or breakfast on a good day.
Jon H is offline   Reply With Quote
Old 10-31-2009, 06:24 PM   #24
2000 velocity 390
My friend has the 1st vr1 sold as a pleasure boat . 72-74 gps with a 496 mag ho. 425 hp. The 1st was a race boat.
Velocity Tom is offline   Reply With Quote
Old 10-31-2009, 10:58 PM   #25
If I were you I would pay a lot of attention to prop selection, x dimension and prop shaft height. At least my 22' it seems to be sensitive to prop torque and I would assume yours would also be a single engine application. With mine the higher you trim it the more stable it becomes at 70+. Have you given any thought to using that NXT drive that mercury makes specifically for single engine application? I've heard it works very well.
DisturbedVelo22 is offline   Reply With Quote
Old 11-01-2009, 04:23 AM   #26
2003 Velocity VR-1
I have been following Pit Bull's posts regarding props with interest as it may save me some dough.
Not familiar with the NXT drive, is it a duo prop? I will look into it, thanks.
Old 11-01-2009, 06:12 PM   #27
No its a single prop (which is great because reproping won't cost you an arm and a leg). The skeg is actually turned to make up for the prop torque so that the bullet and the rest of the drive can stay straight while the skeg makes up for the prop torque.
On second thought it might be more like #6 then a bravo. This boat has it, it has a separate transmission. I don't know, I read an article about it from 2007 that sounded pretty neat. Might still be worth looking into. The article made it sound like its a very tough, very dependable drive so if you're going to be bombing around in heavy chop at high speeds it might be worth your while.
http://www.offshoreonly.com/classifi...o27600-en.html
Old 11-02-2009, 03:54 PM   #28
Revelocity's Avatar
Velocity 390 and Velocity 220
Unless things have changed (bad economy etc.), Mercury Racing only sells the NXT drive with a blue motor. At first it was with their 700 package but it's now available with the 525. Merc Racing only warrants the drive up to the 700 motor.
Revelocity is offline   Reply With Quote
Old 11-02-2009, 10:34 PM   #29
notd1
If you go with a 496/425 , the bravo should hold up pretty good . I have seen friends get 100's of trouble free hours on those
496's
Old 11-03-2009, 01:56 AM   #30
Crazy Energy
Velocity Vector's Avatar
35'Ocean Express Cat
Quote:
496's
I'm your friend and I got 100's & 50 on mine when she **** the fince but I fixed it. Heee!
The true measure of a man is how he treats someone who can do him absolutely no good.
Velocity Vector is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
