Next project is a CAT
#151
Not being rude either but shut your stinking sht hole let him build his boat dik hole
#152
Crazy Energy
1 Post
[ATTACH=CONFIG]503609[/ATTACH]
5 1/2" Missal launchers Photo
Andy are you holding back, I don't remember you being so polite.
#153
Crazy Energy
1 Post
Before machining
This is what I'm making the exhaust trim rings out of. I have 3 of these Aluminum 5.75 ID X 7.75 OD X 2" Wide.
I plan on cutting 2 of them in half for the 4 outside transom rings 1" thick.
The other one in 4 pieces 1/2" thick for the inside transom.
[ATTACH=CONFIG]505241[/ATTACH][ATTACH=CONFIG]505242[/ATTACH]
After machining
Finally got my trim rings machined for the 5 1/2" cannons. We beveled the outer and inner of the outside rings, drilled 6 holes on the inside of the outside rings so no bolts will show from the outside of the rings and inserted Heli Coils in the holes so the aluminum won't strip out. Now they are off to be anodized
[ATTACH=CONFIG]505243[/ATTACH][ATTACH=CONFIG]505244[/ATTACH]
[ATTACH=CONFIG]505245[/ATTACH][ATTACH=CONFIG]505246[/ATTACH]
Heli Coil
[ATTACH=CONFIG]505247[/ATTACH]
After machining
Heli Coil
#154
Crazy Energy
1 Post
I got my exhaust rings back from the anodize guy today. I had them done in 2 staged black. The drives / tunnel tab / and rings are all black. I'm very happy the way they turned out.
[ATTACH=CONFIG]505939[/ATTACH][ATTACH=CONFIG]505940[/ATTACH][ATTACH=CONFIG]505941[/ATTACH][ATTACH=CONFIG]505942[/ATTACH]
#155
Crazy Energy
1 Post
[ATTACH=CONFIG]506242[/ATTACH][ATTACH=CONFIG]506243[/ATTACH]
I bought some insurance.
2- Hardin marine 2 stage sea water pumps and 2- Whipple mount sand strainers.
#158
Crazy Energy
1 Post
Bob has Finished the engine compartment on the Cat Project. She looks like a naked lady waiting on chromed transplants. There is a difference in a bilge that's been painted and a bilge that's been painted right. The time, patience, and work that went into this is bar none as nice as it gets. Thanks Bob!
[ATTACH=CONFIG]512247[/ATTACH][ATTACH=CONFIG]512248[/ATTACH][ATTACH=CONFIG]512249[/ATTACH][ATTACH=CONFIG]512250[/ATTACH][ATTACH=CONFIG]512251[/ATTACH][ATTACH=CONFIG]512252[/ATTACH][ATTACH=CONFIG]512253[/ATTACH][ATTACH=CONFIG]512254[/ATTACH][ATTACH=CONFIG]512255[/ATTACH]
