Go Back   Offshoreonly.com > Owner's Forum > Velocity
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-26-2002, 08:50 AM   #1
2001 Velocity 280
Red Warning Light??
The Red Warning light on the console came on and beeped twice while I was out yesterday. Its never happened before. The oil pressure and temp all looked OK. What all is the warning light for? It's a 2001 Velocity 280 502 EFI. Thnaks Chris
LakeBum is offline   Reply With Quote
Old 05-26-2002, 04:03 PM   #2
mmo jo
Check your drive oil bottle.If its a little low that will do it.
Sponsored Links
Old 05-26-2002, 06:46 PM   #3
2001 Velocity 280
Yes!But where is the engine oil going?
That was it..I had checked it earlier and found it was low and added some fluid. No more Red Light !! Now if I can just figure where the heck all this engine oil is going. With 39 hours I shouldn't be adding a quart every 3 hours should I ? Although the guy up at the Fountain place says he uses a quart every 2 hours. But has thin rings. I'm not smoking and no water in the oil and no oil in the engine compartment.
Old 05-26-2002, 11:22 PM   #4
mmo jo
What oil are you running?
Old 05-26-2002, 11:26 PM   #5
2001 Velocity 280
Oil
Everyone told me to run Mobile One ...but the guy I had change before then put Castrol 15-50 so thats what I've been adding till I change it to Mobile one.
Old 05-26-2002, 11:30 PM   #6
mmo jo
I had the same trouble.I switched to straight 40 weight.I used 1 qt every 20 hrs.And I run hard.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Warning light Sam69 Cigarette 4 06-29-2008 08:39 PM
Red Dash light... Sam69 Cigarette 5 05-06-2008 08:48 PM
warning light senders Zanie General Q & A 0 06-29-2006 08:37 AM
Warning Light Stays On roarkace General Q & A 3 06-20-2006 11:48 AM
Why is the warning light on? SkiDoc General Q & A 4 06-08-2006 07:43 AM
Search Engine Optimization by vBSEO 3.2.0
