Sea strainer on 280 >
Sea strainer on 280
Sea strainer on 280
Old 07-25-2016, 09:43 PM
Default Sea strainer on 280
I'm thinking about installing a sea strainer on my 2002 280. I never had any issues but think it can't hurt.
Does anyone have pictures where they installed one on a 280?
underpsi68 is offline
Old 07-25-2016, 10:17 PM
Revd Up's Avatar
Here's mine.
Revd Up is online now
Old 07-26-2016, 12:30 PM
Thank You!
Old 07-29-2016, 04:43 PM
Nice setup Revd!!!
CJSYD is offline
Old 07-29-2016, 05:21 PM
Revd Up's Avatar
Thanks!
Old 07-30-2016, 06:06 PM
WOW! That is awesome!
darobinson23322 is offline
Old 10-24-2016, 08:08 PM
Who makes that strainer ?specs on bung size ? How's you mount it ?
Bajajay98 is offline
Old 10-24-2016, 10:56 PM
Revd Up's Avatar
Its a KPM. It came with the male hose barb fittings that screw into the different ports. I don't know the exact size, but I would guess close to an inch.
It comes with the mounting base that I have bolted to the floor. The piece you see with the holes in it is like a clamp to hold the cylinder, That clamp is part of the mounting base, and allows you to turn the strainer to your desired position, then clamp it tight.
I bought it in 2006 for about $400. I am not sure if they make these anymore, as I haven't seen any lately. I have seen others that look very nice though.
Old 10-25-2016, 08:11 AM
Revelocity's Avatar
Most of the strainers in the market have a 1' NPT female openings for male hose (1.25" hose sze) barbs. As i recall the Gil Style (now Hardin/CP Performance) can be ordered with permanant male hose barbs. Most mount on a vertical surface like a stringer or bulkhead but it should be pretty easy to horizontally mount attaching to an L-bracket screwed into the horizontal surface.
Revelocity is offline
