-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Looking For Pat (https://www.offshoreonly.com/forums/active-thunder/117737-looking-pat.html)
Active Mike 12-03-2005 11:39 PM
Looking For Pat
Pat,
A reminder that I purchased the 25' tantrum that was built for Smith Bro Racing. I have been trying to get rid of the porpoising that I get from this boat and was going to have the hull looked at. What is the specs for my hull, hook, no hook and if any hook what would you of put into it when you built it?
I'm trying to get this boat to settle down with out loosing any of my valuable speed.
Looking forward to hearing from you.
Thanks in advance,
Mike
thunderdan 12-04-2005 09:40 AM
Re: Looking For Pat
That was a great boat. I bought it from Pete Smith. It would porpoise at wide open throttle about 77 mph. Remember it is only a 25 footer.... At those speeds the only thing that is in the water is the prop....There was one thing that I used to do when it would porpoise like that..........slow down and drag some tab... :D
Griff 12-04-2005 02:29 PM
Re: Looking For Pat
I know Gordo has said his 25 AT gets a little porpoise in dead calm water. He said it goes away with a little chop in the water.
Active Mike 12-04-2005 11:30 PM
Re: Looking For Pat
Thunderdan,
Good to hear from you. I'm looking for perfection with this boat. I want my cake and eat it to. I can't believe that the porpoising can't be dialed out of it and that is the road that I'm on.
I appreciate your feed back and any thing that you can add on coming up with the answer to my problem I would appreciate it. That is why I'm looking into the hull.
Thanks,
Mike
Active Mike 12-04-2005 11:36 PM
Re: Looking For Pat
Griff,
Gordo does experience some porpoising with his on smooth water. I have mine all the time at upper speeds. Drop tabs scrub speed. That takes all the fun out of it trying to go fast.
Looking for Pat to let me know what they do on factory hulls on these boats and how they perform.
Mike
ActiveThunder 12-05-2005 08:20 AM
Re: Looking For Pat
Mike,
Not quite sure what to tell you other than make sure the keel and strakes are straight. If you have a box, which I think you do, maybe it is upsetting the apple cart.
Pat
blaniac 12-05-2005 10:26 AM
Re: Looking For Pat
Mike,
Pat
Pat
How is my 33' coming along ?? :drink:
Can I get a pair of tix for the Miami show ?? :D
Steamin Rice 12-05-2005 11:29 AM
Re: Looking For Pat
Originally Posted by blaniac
Pat
Blane,
Did you step up to the 33?? If so, congrats..
ActiveThunder 12-05-2005 07:47 PM
Re: Looking For Pat
Pat
Blane,
In one word: 'nicely'. Quite honestly it is a total hot rod.
Now, are those tix into the show or tix on a plane?
Pat
Active Mike 12-05-2005 10:44 PM
Re: Looking For Pat
Mike,
Pat
Pat,
I removed the box last year do to the fact that I thought it would eliminate the porpoising problem but it didn't.
The question that I have for you is should the hull have any hook or rocker in it, either side? There is some hook in the port side but not in the starboard side. I'm looking to get the hull back to Active Thunder standards.
Could you get back to me on this?
Thanks,
Mike
