-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   difference between 37 AT 2000 and newer ? (https://www.offshoreonly.com/forums/active-thunder/121318-difference-between-37-2000-newer.html)
26sonic 01-25-2006 08:06 PM
what is the difference besides the step hull between a 2000 37 AT and newer ? how fast will the 2000 run with 500efi's (non-step) ?
docmanrich37 01-25-2006 08:12 PM
Re: difference between 37 AT 2000 and newer ?
I think it's around 83-84.
excursion 01-25-2006 08:51 PM
The NON-STEP hulls are considerably slower than the stepped hulls. AT did not make many more of them after the step was brought out. You will be lucky to get 75mph out of that boat with 500's..
I would keep the look out for a stepped hull.
docmanrich37 01-25-2006 09:03 PM
Forgot about the step wasn't on it in 2000.my mistake
rssteiny 01-26-2006 06:45 AM
my 2000 32 a/t with no step and 500 hps w/ a tad bit of work done to them runs 84-86 on gps.
ActiveThunder 01-26-2006 07:03 AM
2 AVHs were built for model tear '99. Only one V-bottom with 500 efis was produced in 2000.
