Need A prop!
I need a 4 blade 26 for my 28 AT savage w/ a 525efi and Bravo XR. Do these boats spin LH or RH props? thanks vic
Right hand , but cant help on the prop , sorry
I have a 26 bravo 1 and a labbed 28 bravo 1 both are for sale. Pm me a phone number and we can talk price.
Vic,
I PMd you. A right-handed 26 was stock. Did it fall off? See what John wants for his 28 lab. It would be a good choice. Pat |
John pm sent
Thanks for the help
Try a 4-blade 29" Hydromotive and have Throttle Up lab finish and reduce diameter if you need a few more rpm's. Just a thought....If cost is not a factor(haha) try a 5 or 6 blade and get Matt or Julie @ Throttle Up to work with you...they know props.
correct me if I am wrong but a bravo1 prop will not work on an XR drive because of shaft size???? With that said I have a 28 for an XR
Originally Posted by cosmic12
(Post 2073175)
(Post 2073191)
Same prop you just have to change the hub insert.
Bravo props are the KINGS of BOG! Try a Hydromotive & go up 1 or 2 inches in pitch...lab it...and if you need a few rpm's then reduce diameter, but start with an 1/8" or less. You can take more(for free if you use Throttle Up), but you can't put it back!
you been talk'n to Clark?:evilb:
(Post 2073193)
can't change the hub in mine
I will take a long look at mine when I get home,but I don't remember seeing a removable hub in it. I know that I have had brovos with changable hubs but this one ????? I am in Ca. now for a nother week and half I will ck it though
I use a small brass punch and tap mine from the back end till its loose then flip the wheel over and pull it out.
I will ck. Did you get Over Active home yet?
(Post 2073233)
Good luck and I hope the weather holds for the tow.:cool:
(Post 2073257)
Calling cosmic 12
Interested in the prop- thanks vic
Got one
Got a prop going to give it a try and see how it works-still want to talk to cosmic 12 about his 28 pitch. thanks vic
sorry I am out in San Fran Ca and my computer only works when it wants to. I will answer your pm
I am still away
I am in south Fla. taking a break from the sun and found computer- PM me a price on the 28 then I can look into labbing it. If it makes for a decent deal I will take it. thanks vic
Shack, I looked at my prop and there is no removable hub, the splines are machined into it, solid hub. go figure:confused:
| All times are GMT -5. The time now is 10:15 PM. |
